RogerS
Next project is to lay some oak floorboards in my study. It's L-shaped. Trouble is that the floor level (driven by the old oak beams below) is all over the place. From the door threshold it dips down but then starts to rise as it nears the far wall. And keeps on rising to end up about 1-2" higher than the door threshold 4m away. A step at the door threshold is out of the question as the door height itself is very low to begin with. I can live with a slight upward slope from the door to the far wall.
If the slope does look to be too much then I can remove one of the existing chipboard floorboards by the far wall to drop the end height. So that's all good then.
But not only does it dip then rise in this direction....it slopes down on the other axis. You can see from the photo how much.
but that's workable as well.
The main problem however is the L-shape bit because the floor rises quite steeply and then flattens out for the last metre.
The increase in height is large....and if I take a level back from this point to the starting door threshold then there is a height difference of about 4". So Plan A was to put a step in at the start of the L-shape. This seems a logical place to me especially as at some point in the future we might convert the far end of the L-shape to be an en-suite.
I could see it all coming together...bearers fixed to the chipboard and adjusted to height. It would even hide this kink in the floor by the door.
Then Chief Designer vetoed the step. "What's wrong with having sloping floors in an old house. A step would be just plain wrong."
So - Plan B. Lay the oak floorboards straight onto the chipboard. Only problem is that that chipboard is not coplanar. Nowhere near. So I'm looking at fiddly little bits of spacers, trying to guess their positions. Otherwise the oak floorboards are going to be all over the place with gaps opening up between some of them. I reckon they are going to flap around as well as they will end up floating above the chipboard on high points.
Which seems to me to be a bit naff.
So I am stumped. I can't see an easy way to do this. One option might be to take up the chipboard and then lay my own sub-floor supports coplanar but it's still going to be a ******* as I am effectively laying a sloping floor....so levels aren't much use. Time for some alcohol. Lots of alcohol.
