Axminster m950 drive centre
supergoose
New member
21 Dec 2024
Barnstaple
Hi,
Recently acquired an axminster m950, and in my haste to try it out I purchased a 2mt drive centre from axminster.
Upon trying to use it, it fits the tailstock,not the headstock- it's far too big.
The manual says the spindle is 1 inch, 8 tpi, 2mt taper- and that the tailstock barrel is 2mt which is why I assumed it would fit either end. I realise now that the manual describes the spindle, rather than the tooling that the spindle will accept.
What do I actually need to do to use this lathe for spindle work? The manual is fairly light on any detail, and I can't see any type of tooling that fits on the current spindle that would accept another 2mt tool?
Many thanks in advance
I removed the face plate. The headstock is now just the spindle which has the hex shank followed by a one inch screw thread. The hole in the part with the screw thread is around half the diameter of the tailstock.
Sounds like a number one morse taper.
Can you get a photo with a mm rule showing the dimensions of the hole, After Christmas I will measure a 1mt live centre and a 2mt live centre I have here
Ok won’t be nasa standard but it should point you in the right direction.
I am in titchfield so I can’t even say pop round, borrow a 1mt to try
Ok as it’s Christmas and I am a softie post the pic, I will look as soon as I can. Maybe even LEND you a 1 mt drive centre to try
That way you get to play,
I had a 950 and it was 2mt both ends. There isn’t a mt2 to mt1 adaptor is the headstock spindle, is there?
