OBD scanner
artie
Sawdust manufacturer.
12 Jan 2015
Norn Iron
My trusty Ford has been giving some problems.
The DPF filter/sensors/regen etc
So I bought a Autel ap200 scanner to help diagnose.
It worked quite well but expired after only 3 months.
Autel UK didn't want to know and neither did Autel.com.
So I think I'll avoid that brand again.
So do you guys have a recommendation for a basic scanner that doesn't break the bank.
You might need more than just a basic scanner if you wish to resolve the issues otherwise some of the more basic ones will just have you going round in circles.
So if you think you have found a faulty DPF sensor are you actually going to replace it yourself, one of our cars was diagnosed with a faulty EGR sensor but the actual fault was the MAF sensor and this was found using diagnostic's from two different systems and the guys experience so often just cheaper and easier to get it looked at than spending a grand on some diagnostic tool which still leaves you with the task of then actually checking and replacing components.
The dpf problem is hopefully sorted, but I'm thinking ahead to the next problem, no doubt there will be one.
I understand that the tool itself in inexperienced hands is not the full answer. But my time is cheaper than a mechanic who sometimes won't want to spend time investigating and jump to a conclusion without checking every avenue.
Plus it's another toy to play with :)
I have a cheap Sealy one which has been pretty good, about £30 when I bought it quite a few years ago. Will read basic codes on anything, and enable you to reset basic stuff.
Above these you have a choice
For more detailed stuff you either need something make specific, so pre configured for Ford or BMW or whatever. That will show you stuff the regular one won't. They are maybe £100. Great if you always buy a particular make, although these often also give enhanced features on other makes as well.
I have one which is specific to Mercedes, mainly because it can connect up to their old round, pre OBD, socket as well as the later ones. This is made by icarsoft, about £150. Very good quality unit and I have been very pleased with it.
They do a big range, including all makes types.
Then you get into the ones that can get into a big range of makes with increased functionality.
These used to be very pricey, and still are if you want a very highly featured and robust one suitable for workshop use.
More recently a lot more have come out offering a broad range of make compatibility and lots of features including showing live data. These are anything from £150 upwards.
There are now so many of these that I can only say read the reviews and specs to see if it will do what you want.
Halfords sell ones from Foxwell, which get good reviews.
I have used one of their basic models and was impressed, very well made and easy to use.
Avoid Carly, which works on tablets/phones. Their subscription model is not cheap and in my experience the information/options offered are not worth it.
I use it on an old Lexus hybrid and a more modern Renault
I can't claim too much experience but picked up something like this perhaps 10-15 years ago.
https://www.ebay.co.uk/itm/285661632225
At this time it was perhaps £10-15 so well in the "take a punt" territory. Doubly so now. It turned out not to be a bad choice, that ELM327 is a magic term, it refers to the control chip which is well understood. When I needed to dust it off a couple of years back there are open source projects online still supporting it and still adding new proprietary codes even if they were unknown when I initially bought it.
It's certainly in the affordable category.
Its a long time since I bought mine (for probably over £50), but I have seen that some of the better apps have a list of supported or recommended scanners. It used to be that the cheapest scanners were safely a waste of money, but I suspect the picture is more complex now.
Have a look at a program called forscan which can be downloaded on to a laptop for free. Then you just need a compatible cable (more info on the forscan website).
There are so many threads about this on all the forums I’m on. It makes me think that none of them are particularly good, unless expensive professional grade.
ICarsoft - first one (i930) died after two years, second one was dead in box. Quite useful when working.
Foxwell - incredibly slow and clunky to operate. A good way to waste an hour, sitting in the driver’s seat trying to navigate hopelessly complicated menus. Rarely contributes anything useful.
For example: even with the autoVIN read function, before it’ll tell me anything, it asks me where the car is from, make, model, year, fuel type, then gives me a list of meaningless engine codes to select.
I end up shouting at it: “why don’t YOU know this?! You’re the one talking to the car’s brain!”
I’ve heard good things about the Topdon AD800 BT-A.
Since I have a Ford I plumped for Forscan installed on my ancient sluggish laptop connected via elm 327 connector.
Presently no faults, but at least I'm prepared for next time.
