HamsterJam
Let’s take it apart to see what’s inside….
I have done this a few times with Forstner bits and brad points/twist drills.
Slow speed (400rpm is slowest my lathe can go) - a bit faster for bradpoint/twist drills (next step up for me is 1000rpm).
Withdraw bits to clear waste and allow cutting surfaces to cool every 20mm or so, particularly for twist drills.
Use a candle to apply wax as a lubricant if necessary.
Hold Jacob’s chuck with left hand while feeding gently with right to avoid morse taper spinning.
Don’t over extend quill in tailstock to keep things tight and accurate.
Keep cutting edges of sharp - use a diamond file to hone forstner bits periodically.
