DBT85":2wzx12pk said:
Did you use wedges to help level the plates on the dpc Phil or did you not feel the need as there was no frame weight on top of it?
I recall Mike using them on the workshop but for that one he put the whole frames up on the mortar rather than just the plate.
No wedges, I used a stiffish mortar mix with febmix, bedded the DPC on lightly, then placed the sole plate on the DPC. After setting the first one dead level with gentle tapping to ease out the mortar, I joined the second which had already had a lap joint cut, gently setting it to level. Just did this for all four sides. By the time I had set the fourth side, I could strap the first side, then worked round doing them all. I had pre routered the groves for the straps by setting them on dry and marking. I also cut the door gap out later when everything was set and strapped, there was no chance of it not lining up that way rather than two pieces of timber.
