Sheptonphil
Scrumpy junkie
No problem, I didn’t buy it today, so will carry on without it.MikeG.":2qrzaekl said:Where polythene is definitely requires around Celotex is when you screed over it. I am not at all clear as to why I showed it in that sketch under a floating floor. In fact, there are two or three things that have evolved over the years to be somewhat different from that old drawing. Mike from 2010 will applaud if you put it in. Mike from 2020 will shrug and say "whatever". Put it this way, I can't see it doing any harm, other than minor damage to your bank balance.
I have a dilemma with the internals of my build. I had always planned to have the extra section at the back a separate room for dust extractor, compressor and sink. Indeed it was going to be built as an addition to the workshop afterwards. With the cut roof as is, the wall that creates the room is not load bearing, and doesn’t even need to be there.
So, do I keep the separate sound proofed room, or remove the wall and make it a single large room. The extra bit is 2.7m x 2.1m. I’ve attached the plan view.
It’s the red wall And grey door between the two rectangles. I’d keep the bit by the sink.
