RobinBHM":3p592n91 said:I hope you get a workable solution from the BCO.
I'm sorry my reply about the regs has thrown a spanner in the works! -you did ask though!
I think what you propose is reasonable, the only question really is whether they will accept a somewhat unproven / untested solution -it is a grey area and if you get a pragmatic building inspector that can see you are making an effort, hopefully you can carry on.
Although building regs are a pain, it does make common sense to have a bit of a fire break between properties.
RobinBHM":1darbs84 said:Are you covering the outside with breatheable membrane, then tile battens laid flat then cladding? -it has a significant impact on long term weather tightness and the air gap allows the cladding to dry out quickly increasing its lifespan.
Halo Jones":2u6x2yv5 said:Hi,
That will be a nice space. I may be wrong as the rules are slightly different in Scotland but I think anything with an internal space over 30 m2 also needs full building control approval and you appear to be just past the limit. Did the BCO you spoke to know the size of the building?
H.
