Trend T7e & Porter Cable 42160 Jig
smiffy151
6 Jan 2024
Kent
Hi All
Please forgive my ignorance if not posted correctly as this is my first attempt... I have a Trend T7 router and have purchased a Porter cable 4216 dovetail jig. I have looked and the Trend T7 will not work out of the box and have seen a Unibase/180 adapter plate that seems to be the correct adapter for the router guides. The guides are two part with one piece through the bottom of the router plate and then a nut that holds the router guide in place.
The adapter from Trend Unibase 180 has two threaded holes on the bottom in the middle where the router bit comes through, however, the router guides from Porter cable are just attached as mentioned.
Has anyone had any experience with this sort of issue or setup, would be appreciative if anyone can offer any information
Would this do it? https://www.thingiverse.com/thing:4011657
You will need a 3d printer.
Hi
many thanks for your reply, unfortunately the Trend T7 router base is a strange one. The picture you supplied is similar to the Unibase 180 that Trend supply but it doesn't support the American style threaded guides which just fall through the hole. Looks like I might have to return the Porter Cable jig and go down the Trend jig route which I'm not sure I like as much but needs must, thanks again.
Smiffy151
There's been a couple of posts, recently about this arrangement, to be honest the outcome's not looking promising from what I read.
https://www.ukworkshop.co.uk/threads/porter-cable-dovetail-jig-4216.150622/
https://www.ukworkshop.co.uk/threads/dovetail-jig.150627/
Hi HOJ
No, in a nutshell a disaster lol. I had the Trend T7 router but it seems it's a bit of a one off in terms of adaptability. After buying the Porter Cable which seems a really good piece of kit despite shocking product support. I contacted Trend who told me that even with a baseplate adapter it wouldn't work with that jig due to the American style router guides (Screw in). Have now ended up buying another router and adapter to use the jig.
Thanks for the heads up anyway
