I guess I can see why the Stanley approach took over. The Norris I have (although not from the high-point in terms of quality) seems to do a good job although no better than my favorite Record SS and Clifton #4 as far as I can tell so far (in terms of tear-out on sapele). I suspect the older Preston I bought a few weeks ago will turn out to be a better tool if I can get a decent iron for it. The iron in that case is set with a hammer - just takes a bit of practice to get it right.Orraloon":3564vr54 said:I have a norris A1 and find the adjuster to be not as good as I was led to believe after reading all those great things said about norris planes. A bit of tap tap on a plane without an adjuster actually gets results with less hassle. To advance the blade is not too bad but the side adjustment does not compare with a stanley. That said when set up a norris does a beautiful job.
Regards
ED65":s3y7803g said:FWIW that dulling caused by vinegar or citric acid is easily counteracted (takes moments to minutes) unless you've soaked for a very long time indeed. Not that I'd suggest either be used here I hasten to add.
D_W":10t92z4v said:For the adjustment of depth, the tighter the lever cap, the deeper the cut. If you set it just shallow of cutting with the lever cap loose, you can use the tightness of the lever cap as micro adjuster.
