Eric The Viking":1kgsme70 said:
I suspect we're actually agreeing: are you considering 'dual fan' to be one on the heatsink and one pushing air through a duct from the case down over the heatsink fan? If so I understand what you mean.
I wasn't aware that AMDs run that much hotter. I've only seen that arrangement in HP, Dell and a few others. I'd just assumed it was good housekeeping, as it adds cost.
E.
Hi Eric
No, both fans in dual arrangements are very close to or attached to the heatsink. Case fans are completely seperate (my own desktop has 3, controllable as well as PSU / CPU and graphics card fans.
If you google it you'll probably find them, they are there. More expensive than single fans and not usually used except on high end gaming machines or specials that are overclocked. I once fitted a water cooled system which I couldn't get my head aroung (water / electrics!).
AMD CPUs have traditionally always run nearer the top of their operating capacity than Intel and therefore hotter. The AMD spec is (or was) slightly lower but output similar. That's why Intel were much easier to overclock due to the margin of capacity available and why earlier AMDs needed special heatsinks and tended to have a shorter life. Not quite as simple as that but gives the gist.
Except for the last couple of years I've built a lot of pcs for a lot of people but that was when you could make a few £ out of it.
The first ones when memory was tiny and expensive and hdds held little more than the operating system (DOS then win 3.1 :roll: ). My first CD writer was a Sony tray model X2 speed and you were lucky if you got 1 in 3 good disks out of it - That cost a wopping £395 :shock:
I would never suggest that anyone inexperienced should remove either CPU or heatsink but the fan, if single is only held by a maximum of 4 screws and sometimes just clips. If the CPU isn't soldered to the motherboard (rare) I would always remove this with the heatsink and separate on the bench. It isn't difficult but a novice could bend the pins or damage components with static etc.
What you and Jake said about separating heatsink and CPU is right but it really isn't difficult and just commonsense. Static wrist strap, very thin blade, careful cleaning and re-attach using a new pad or heatsink compount and its as safe as houses. I've never had one fail - but I've had a lot of practice.
Anyway, back to the original post. DW from his questions clearly isn't experienced and unless it's a case fan shouldn't do it himself.
A case fan however is so easy that anyone getting in a pro to change it is throwing their money away and I'd suggest that anyone capable of using handtools or machinery is very competant.
The arguments about push or pull for CPU fans will be there still I suspect (all forums have their share of Jacobs - couldn't resist - sorry). It's another subject.
Bob
