SteveB43":20vwgy04 said:Maybe a silly question, but these aren't just for clearing out and smoothing housings right?, and why would you want a paring chisel over an inch wide, surely for precision work you'd want something half inch or less?
All musings and uses for a paring chisel gratefully received,
Cheers!
SteveB43":kuugv6xf said:Maybe a silly question, but these aren't just for clearing out and smoothing housings right?, and why would you want a paring chisel over an inch wide, surely for precision work you'd want something half inch or less?
Cheers!
"Each man knew his chisels and mortise gauge perfectly, and no tenon
was ever trimmed to thickness with a plane or a chisel - unless
something somewhere had gone wrong; then the comments and asides
would fly, to the embarressment of the unlucky victim. Similarly, no
shoulder plane ever touched a shoulder, unless an unusual or
unfortunate accident had occurred; this was because the sawing was so
accurate, no cut ever being made across the grain without a
preparatory V-groove. The long paring chisel was always on the bench
and in constant use, especially when making the V-grooves. The wood
was held either in the vise or against the turn-buttons that were
screwed to the far edge of the bench. The chisel was picked up and a
cut made freehand in the scribed shoulder line, the chisel turned
over in the hand so quickly that it was difficult to see, and then
the V formed - the waste peeling out in a continuous strip"
Heath Robinson":24f1xfvg said:I'd love a look at this, and the chap I share a workshop with, who's a pattern maker would be both a good judge, and keen to see it.
Paring chisels have been a part of our conversation quite often over the last few weeks, so this seems fairly serendipitous!
SteveB43":39puvtbf said:Maybe a silly question, but these aren't just for clearing out and smoothing housings right?, and why would you want a paring chisel over an inch wide, surely for precision work you'd want something half inch or less?
Cheers!
+1 to Matthew too.morfa":hegu6356 said:I really didn't notice any play in the handle I have to say. The sheets of scary sharp passed me by as well. Oh well. I would agree that they're very handy. I only used mine for a DIY job (trimming a in situ piece of wood so a panel would fit) but it was much better than other chisels.
I think if there's no one else interested, then you just send it back to Matthew @ http://www.workshopheaven.com and he'll auction it off for charity.
I'd just like to say 'thanks' to Matthew for doing the passaround, it was very useful for me.
Heath Robinson":nvd9c4bm said:After having this for a few days, I've noticed a few things.
Firstly, the handle is a little loose. Not disastrously so, but there's play there. Doesn't seem inclined to come off though.
Secondly, the blade seems to be a bit softer than some of my other sharp things. It could be down to the finer angle of the bevel, or just my perceptions being out of whack, but I'll have a better comparative test this week. I'll also try a "how long will it stay sharp" test next to one of my other paring chisels (though they wouldn't be any comparison for hardness via sharpening feel/speed really, as they're much thinner blades), with an oak off cut.
Thirdly, I'm really considering having one of these in a little holster about my person at all times! It's quite surprising how many uses I've found for it. There's a few odd jobs where there really isn't a substitute for something long and sharp. Adjusting jigs, trimming inside drawer runs, removing tonsils, altering a weird lighting project's internal cavity after the glue had set, haranguing visitors to the workshop, to name but a few.
Fourthly, the handle (play aside) has really grown on me. Being quite chunky, it seems to give a nice level of control over the tip when most of the blade is out of reach, inside things. I think I'd like it to be shorter - it doesn't fit inside my toolbox chisel-hanging rack with the lid closed :-( but I think that one day I'd like to try a range of handles on one chisel blade, to see which suits me best.
Isn't the first quarter of an inch (or thereabouts) a little softer than the rest of the blade? Think I read or heard that somewhere. I picked up a couple of the Narex beveled edged chisels and was going to get a paring chisel also. I haven't worked with the chisels yet as I have them only a short while and haven't flattened or sharpened them.
Having recently acquired a Veritas honing set-up (courtesy of Aces and Eights, many thanks!) and discovered some scary-sharp honing sheets in the packing tube for the chisel, I'll get a really precise bevel on this and one of my other parers, and apply them to the oak later in the week.
What happens now, then? Does anyone else want to have a look at it? Or do should I send it back? Or, better yet, is it like pass-the-parcel, with me as the last unwrapper... ;-)
I must say, for the price, I'm sorely tempted to buy a set of these.
Heath Robinson":51mtegu9 said:After having this for a few days, I've noticed a few things.
