Benchwayze
Gary,
That remark is so 'throwaway' it isn't worth discussing. :roll:
Benchwayze":27aoq8nd said:Gary,
Maybe not best practise, but if it ends up with a working platform adequate for the needs of a particular woodworker to get on and produce some output then what's the problem.David C":lwo8wv32 said:Because it is bad.
David
Gary,GazPal":13vsenju said:Benchwayze":13vsenju said:Gary,
Then why mention it? lol (Resisting the use of a derisive remark in counter balance to the one you chose)
The meaning behind my former comment encompasses the simple fact there are so many methods available and just as many schools of thought, but the one prescribed by Paul Sellers simply outlines one available to those with minimal tooling - working al fresco - and illustrates a method that's perfectly capable of producing a useable workbench top. Primary emphasis is placed upon "useable" and there's no mention of any intention to produce a high-end project or showcase piece.
CHJ":38u3xr0k said:try doing this without such.
. Well spotted John. It is a demonstration of how to make a good bench for a weekend-woodworker who has no workshop, struggling on the lawn, to do a decent job, in the face of few resources and as such, excellent. He makes the point at the beginning - this is how you'd do it with wood from the sheds, with limited resources.he looked like a weekend-woodworker who has no workshop, struggling on the lawn, to do a decent job, in the face of few resources
Jacob":2ptj0mr3 said:I had a look at the video. Impressed by Sellers ruthless practical common sense. A very effective approach if you only have 3x2", in fact a more stable result than using a single piece. Couldn't fault it, what are the objections?
I'd call that best practice - for a workbench not a piece of posh furniture. And I agree with him about the design; very practical, very easy to make. The best design for a beginner, but once you have it you'd keep it for 30 years or more and never need another one. Or do a two beam version like mine and just turn it at half time!
Benchwayze":2yybt4s4 said:Gary,GazPal":2yybt4s4 said:Benchwayze":2yybt4s4 said:Gary,
Laugh if you wish. While you laugh at me, you're leaving someone else alone.
As to that shambolic video you seem to like, IMHO:
If you want a bench-top that doesn't require maximum effort to flatten after gluing; (He works by hand remember) it isn't sufficient to just squint across the dry-run it and say. 'Perfect!'
If you want a bench-top that isn't going to move sixteen ways from Sunday, as soon as you have a dry-spell, or a humid spell, it isn't sufficient to squeeze the pieces together by hand and say. 'That's great. The glue will hold it. It will never come apart.'
I thought that video was laughable, and despite all the experience he has, he looked like a weekend-woodworker who has no workshop, struggling on the lawn, to do a decent job, in the face of few resources. He says he did that to show it could be done. Maybe, but Gary, if you think that an acceptable; nay perfectly capable way to make a bench-top, then you aren't the craftsman I thought you were.
(hammer)
Benchwayze":16mi03lv said:As it happens I have expressed concerns to him. All I get is a reaffirmation that his way is the best. No consideration of the concerns. As others have remarked, his way is THE way. I won't waste any more time worrying over it and by default, no concerns over lawyers. I am entitled to an opinion, and to express it. I would never say HIS CV is baloney, but I've seen plenty of them in my time that were, to say the least, a bit fuzzy round the edges; and I dare say, so have you.
J
Corneel":1t90m4ur said:woodbrains":1t90m4ur said:Jacob,
You still haven't answered the question! What sort of magic does the cap iron bestow to prevent tear out? Explain it, go on. Because I'll tell you this, when the answer is inevitably, chatter can cause tearout and reducing chatter reduces tearout, you just get insulting to avoid the inevitable. If you were worth the effort, I would explain why chatter is a physical property inherent in everything, and denying its existance is like denying the earth goes around the sun. It is just foolish and banging on about it will never make it true.
Mike.
Mike,
I'm afraid you are wrong about chatter causing tearout. And I can proof that in two directions.
1. Unlike Jacob I have had my fair share of chatter. Especially on the start of a cut. Now I know it is mostly a technique thing and can easily be avoided without droppin money on the problem. But a thicker blade or thicker capiron does indeed help against chatter when you are yet not proficient enough. But having seen all that chatter, I've never seen it accompanied by tearout! And when I see tearout, I don't see the typical chatter lines. Watch those pictures on Paul Sllers blog. The first one is chatter without tearout. The last one is tearout without chatter.
2. You can do a little experiment yourself. The working limit of the capiron against tearout is rather small. At 0.5 mm you won't see much improvement. At 0.2 mm you suddenly can plane everything without tearout. The change is rather dramatic and has to be seen to believe it. Now, at 0.5mm the plane iron is still very well supported by the capiron, but it seemingly doesn't help agaainst tearout.
The effect of the capiron against tearout is not in limiting chatter. It is about the caprion pushing the woodshaving back into the surface so it can be cut instead of torn apart.
Tear out happens when the wedging force of the blade is higher then the natural bond between the woodfibers and can only be mittigated when somehow the wedging force is lessened (steeper pitch, thin shaving) or when the wood is better supported (very very tight mouth, close set capiron).
AndyT":3mv28add said:Sorry if I missed it but nobody seems to have posted any pictures of the work that Paul Sellers has in his online portfolio. I do think that if any of these turned up in our Projects section there would be plenty of appreciative praise for his craftsmanship:
