Charlie Woody
Shortly after moving into my renovated workshop I knocked up a very rough and ready bench from some offcuts of timber the builders doing our extension left and some MDF. It was just pocket screwed together with 18mm top.
So time has come to make something more sturdy, capable of supporting my Record 52E Vise, and not costing a fortune. Anyway I decided on making http://www.finewoodworking.com/Workshop ... x?id=29507
but decided to change the measurements to metric and amend the size a little. Also I will put a back in behind the bottom shelf. For the moment there will not be a top shelf but in the future I may add some drawers.
So I purchased some Birch Ply 18mm for the framework and 2 pieces of 25mm MDF 1850 mm x 750mm for the top, and some Maple to lip the bench top.
The first thing I needed to do was make a ZCI for my table saw to reduce tear out when cutting the ply. So with apologies to Steve Maskery for stealing his idea (but honest gov I did modify the design!), here is what I did.
This is the original insert with the blade guard off showing the fixing screws loosened.
I decided to try and keep the piece of MDF whole i.e. not rip and glue in fillet when adjusting for the riving knife. See knife just coming through below.
This is the blade and knife coming up.
Next job was to make a featherboard that I could clamp to the rip fence. See cutting process below.
Next I cut off part of the ends so that the feathers would have a little room for movement.
Featherboard attached to rip fence.
First few rips and happily no tearout ...result!
These are the apron & stretcher parts.
And these are the leg parts.
The only disappointment was my inability to keep the sheets parallell with the fence when ripping. I was supporting them with a roller stand at in & out feed. The rollers being smaller that the width of the boards (the supplier had ripped them down the middle for me - allows me to get them in the car and less weight / size for handling) seems to make them "sway" as the roller in effect becomes a pivot point. I would love to know how to avoid this so if you have any suggestions I would appreciate it.
Does anyone know where I can get an aerosol of Record blue paint please?
Hopefully tomorrow I will get a good bit of the glue up done.
