SkinnyB
I picked up another one of these small Multico Planers a few months back. With lockdown I have managed to get through a few machines I had waiting to be stripped and re-built.
This is the original thread for the first one I rebuilt. Im only really going to include anything that was a little different this time around.
multico-b2-planer-restoration-t113265.html
So here is what I got. Looks to be in good shape, few knobs missing here and there and the belt guard missing. So those will need to be replaced.
Multico planer 2 by jamie skinner, on Flickr
The Fence is different from he previous one I did up. This one uses a dovetailed bar whereas the other used a round bar for the fence adjustment. This design is much nicer as the table cannot rotate left or right.
Not sure if this is original... Maybe support for bolting to wall?
When I took it off it was well made on and had a pin to stop it from rotating when bolted from under the table. Then it was very badly welded on...
Perhaps they were lacking a pulley puller? I can only imagine the pulley was stuck on and in the wrong place so this was considered a quick fix. Someone decided to weld a pulley right onto the motor shaft...
Starting to break it down. Bearings came out easily.
This is the metal bar attached to back of the machine I mentioned earlier.
A member had asked how to get these pins out so here is how I think I remember I did it...
Remove the grub screws holding the lower 4 pins in to the main casting of the planer and soak with penetrant.
I think 4 grub screws are under the casting and 2 are at each end.
Remove grease nipples from pins and give a good spray of penetrant in there to.
Using a hammer and a long blunt ended rod tap each pin out. Careful not to damage the threads in the pins and not to dome over the ends.
Once those 4 lower 4 pins are out the table should lift off, oh you need to remove the handles too. they have pins in and are very hard to get out. I drilled them in the end.
The next 4 pins have grub screws under the table, again soak the whole pin in penetrant.
Tap the pins out as before.
I managed to get all the pins out except this one. The threaded part you see wrapped around the pin was so tight it would not budge. I tried penetrant, heating, big hammer to no avail.
So went with the Dremel grinder instead and carefully slit it open.
You can see where I bent the thread too... Fix that later.
To tackle the extra pulley I resorted to running the motor and holding the angle grinder to it until I could see the shaft.
Pulled off easy.
Thought I was going to have real trouble with the original pulley put pulled off nice and easy.
Bearings cleaned up, little grease and seem to run well.
Paint removed.
Going for a black and white look for this planer. I did a air cleaner a while back and though the combo went well.
animal-cooler-to-air-filter-wip-t119698.html
IMG_6093 by jamie skinner, on Flickr
Masked, primed, sprayed and top coat.
Some parts which weren't dimensionally critical like the motor pivots I cleaned up on the lathe as they were rusted heavily. Also took out the slight bend it had.
Something didn't show earlier... To remove the grease nipples deep inside the pins that hold the table on I ground down a driver bit of the correct size to fit it inside and remove the nipple.
Time to tackle the piece I had to cut off.
I am going to try brazing at this point I have never touched a welder. (I now have and that would have probably been easier.) Ground down the two sides. I think I should have had some kind of dam in there to stop the braze falling through. Had to deal with he clean up afterwards.
Turned on the lathe, you can see the braze right where I didn't want it to go. Should be enough to hold it together at least.
No drill the right size but a reamer... Bit of a hack but it worked well enough...
Getting the main part back together.
3d printed funnel in place for the extract upgrade. Magnets worked well while it was glueing in.
Lots of nuts and bolts de greased.
Fence polished up.
Most of the parts ready to come together.
Cutter block cleaned up and greased.
More assembly.
Lower dust shoot made on laser cutter and 3d printer.
The aluminium handles were damaged quite badly, lots of flaky plastic and I had to drill them to get them off. So I printed some new ones around a metal core.
Replaced some handle parts.
This knob was missing. Its from the part that holds the guard up and down. I have one on another machine so copied that.
Lil bit of oil blackening. Maybe should have finished the surf a little better looking at that photo.
Next to tackle the missing belt guard. I used my new cnc to cut the parts from Mdf.
Nice the fluffy edges due to using an up cut bit...
Bit of bodge.
Undercoated.
While I waited for that I set the knives after sharpening them on my homemade sharpener.
drum-sander-planer-blade-sharpening-jig-t110129.html
Got them within a thou of each other. Glass like finish when I planed up some oak afterwards.
Coat of black on the guard.
And we are done!
Thanks for reading!
Pulled off easy.
Paint removed.
Fence polished up.
More assembly.
Bit of bodge.
Undercoated.
And we are done!
Thanks for reading!
