John Brown
Freeloading Social media influenza
That's not really a thing that anyone could be expected to work out, as it's totally counter-intuitive.Pete Maddex":2b802r6u said:Jacob":2b802r6u said:If you have the chance to look at a cyclists actual track on the ground (wet/dry roads, muddy tracks etc) you will see that all cyclists weave very perceptibly. Faster they go the longer the swing from side to side.
Cycling (and motor biking, skiing or skating) is series of controlled falls from one side to the other. It's controlled by turning into the fall which throws you the other way by centripetal force. So if you are so close to the kerb that you can't turn towards it you will fall off. Except of course were the weaving path at it's outermost point just reaches the kerb .
If you tried to ride a bike with the steering locked it's virtually impossible and is more like tight rope walking where you balance with the aid of a long pole or your arms stretched out.
Jacob
If you want to turn right on your bike which way do you turn the bars?
See if you can work it out.
Work this out instead:
If I take a wooden sphere, and drill a hole symetrically from one side through to the other, such that the centre of the drill bit passes exactly through the centre of the sphere, and exits fully at the far side, what is the volume of wood remaining in what was the sphere?
Then tell me, hand on heart, that you didn't google it.
