JustBen
DrPhill":l9lcwa1p said:JustBen":l9lcwa1p said:There's a Highway Code?!?
Only for bad drivers. Good drivers make it up as they go along.
I thought the rule was "Drive it like you stole it"...
Finial":3uxdpbx7 said:Thinking a bit more about cyclists and harking back to when I used to ride a bike as a kid, seems to me that these days cyclists are not quite as road/pedestrian-friendly as they were then. For example, I seem to remember having a wing mirror to check before I pulled out to go past parked cars. These days I have yet to see a cyclist even bother to look over their shoulder.
Shoulder checks are important, but it would be nice if drivers automatically gave space for riders to pull out. What else do they expect to happen when a bike comes up to a parked car? I'm sure you do Roger, as you have ridden a bike yourself, but in my experience few drivers do.
Terry
Because they don't work on a bike. The handlebars are in constant movement, the frame weaves from side to side, the riders head moves relative to both. They've been tried helmet mounted but still not much good.RogerS":3w0a98oo said:.......
But equally cyclists could also take more ownership of what is happening around them by fitting a wing mirror. Why not? .....
Looking over the shoulder is much more effective, you can see more. The act of looking indicates to other road users that you are about to do something, at least it should. Bikes don't have wings, any other sort or mirror is pretty much useless anyway. Nowt wrong with bikes wobbling, if it worries drivers, stay well clear by slowing down and passing by leaving as much space as you would when passing a car.RogerS":1iqfpv9n said:But equally cyclists could also take more ownership of what is happening around them by fitting a wing mirror. Why not? It's all about driving/riding defensively. If looking over the shoulder on a bike makes it wobble, then the wing mirror makes a lot of sense IMO.
mseries":1jgxhb5p said:Looking over the shoulder is much more effective, you can see more. The act of looking indicates to other road users that you are about to do something, at least it should. Bikes don't have wings, any other sort or mirror is pretty much useless anyway. Nowt wrong with bikes wobbling, if it worries drivers, stay well clear by slowing down and passing by leaving as much space as you would when passing a car.RogerS":1jgxhb5p said:But equally cyclists could also take more ownership of what is happening around them by fitting a wing mirror. Why not? It's all about driving/riding defensively. If looking over the shoulder on a bike makes it wobble, then the wing mirror makes a lot of sense IMO.
Jacob":3j0sdl3x said:NB bikes have to weave from side to side - this is how they stay up.
OK then how does a bike stay up? Surprising how many people don't know this!MMUK":3dd6ab6h said:Jacob":3dd6ab6h said:NB bikes have to weave from side to side - this is how they stay up.
Sorry Jacob but that is complete rollocks :!:
Jacob":3fwnlaf5 said:OK then how does a bike stay up? Surprising how many people don't know this!MMUK":3fwnlaf5 said:Jacob":3fwnlaf5 said:NB bikes have to weave from side to side - this is how they stay up.
Not complete bollocks, it's the micro adjustment of the riders balance as the CoG moves away from the stable base that makes a bike stay up, the forces from the motion and rotating wheels interact too. Speed plays a part. In theory at least a bike should stay up with no wobbles and at higher speeds they do but on roads with riders who are preoccupied with things other than riding in a dead straight line (or constant radius), other factors cause wobbles, things such as bumps in the road, steering round debris, riders movements, wind, imperfect tracking of the wheels, imperfect balance due perhaps to luggage so the rider counteracts it. More experienced riders can do it well and do it smoothly but many over compensate and make their machine wobble more.MMUK":3ds4rla9 said:Jacob":3ds4rla9 said:NB bikes have to weave from side to side - this is how they stay up.
Finial":lbusuuzi said:....
Perhaps. Incompetent, ignorant and aggressive cyclists are a serious problem in this country.
If you have the chance to look at a cyclists actual track on the ground (wet/dry roads, muddy tracks etc) you will see that all cyclists weave very perceptibly. Faster they go the longer the swing from side to side.John Brown":1nmheb2u said:Jacob":1nmheb2u said:OK then how does a bike stay up? Surprising how many people don't know this!MMUK":1nmheb2u said:....
While this statement is, of course, absolutely true, a proficient cyclist can generally keep the "weaving" down to an almost imperceptible level.
RogerS":jvkcpza1 said:From the Times...
Cyclists are almost as likely as drivers to cause serious injury to pedestrians, analysis of official figures shows.
There are bad cyclists just as much as there are bad motorists.
RogerS":2gnv9e4s said:Cycling (and motor biking, skiing or skating) is series of controlled falls from one side to the other. It's controlled by turning into the fall which throws you the other way by centripetal force.
mseries":1vob3q4w said:found this on the BBC http://www.bbc.co.uk/news/magazine-13040607
Pedestrian casualties 2001-09
Killed by cycles: 18
Seriously injured by cycles: 434
Killed by cars: 3,495
Seriously injured by cars: 46,245
Figures apply to Great Britain. Source: Department for Transport
Jacob":2sie5w3p said:If you have the chance to look at a cyclists actual track on the ground (wet/dry roads, muddy tracks etc) you will see that all cyclists weave very perceptibly. Faster they go the longer the swing from side to side.
Cycling (and motor biking, skiing or skating) is series of controlled falls from one side to the other. It's controlled by turning into the fall which throws you the other way by centripetal force. So if you are so close to the kerb that you can't turn towards it you will fall off. Except of course were the weaving path at it's outermost point just reaches the kerb .
If you tried to ride a bike with the steering locked it's virtually impossible and is more like tight rope walking where you balance with the aid of a long pole or your arms stretched out.
