Hello there fellas,
I have a small Jet mini lathe which I have previously just placed on my work bench when using this for turning small knobs, dowels etc.
The lathe is quite heavy and I have not found it necessary to bolt it down. However, I was given a chunk of burr oak (only 8cm square and about 20cm long) and thought I would have a go at making a small candle stick.
Set up as usual and turned on the lathe and it nearly took off dancing across my bench.
On the basis that I may now need to bolt the lathe down what is a good temporary way to do this. I thought about bolting the lathe to a bench hook and holding this in my vice?
Any ideas or suggestions would be helpful. Thanks.
Cheers, Tony.
Cheers, Tony.
