Things that "turn" up
HOJ
21 Oct 2014
South Norfolk
So the request is to make 4 new capitals for some wooden columns, this is the sample I was given:
Some of it hasn't been eaten, enough to make a plan:
The scale:
The plan, at this stage, is to laminate pieces together (vertical) to make up the volume (I'll use bigger sections) which won't give me end grain as such:
I have 155mm over my lathe bed, so will just fit, without the square section though.
By the way, I don't do much wood turning so this will be a massive learning curve.
Quite a job there , I don’t have a lathe but always amazed what can be achieved with a block of wood - good luck and be nice to see your results..
Richard Findley does quite a bit of this sort is stuff. If you can find some of his videos there's a lot of good information about glueing up multiple pieces for a project.
Looks interesting and hope to see some finished pics
I made some similar to that a little while back and I think slightly larger diameter. I used Iroko because the modern fast growing pine won't last anywhere near as long as the original stuff.
The scale:
Curious, I am guessing you are reproducing this capital on a T & M (time plus materials). If you were to give a price would you double your estimated cost ? To cover your you know what.
I used Iroko
I have quite a bit of 3" thick Sapele knocking about so that's probably going to be my route, rather than buy anything in.
I have no idea how to price something such as this, but I have an interest in this type of work, as its far outside the normal routine stuff, so I look at is a means of learning rather than just earning, I will cover my costs though, and hopefully get more work from the client on the back of it.
Made a bit of progress on this today up to a point, cut the blank into the the round:
Made a template for the moulding:
Made a caliper so I can set the diameter:
Put it on the lathe:
Not so good far too much run out, so project abandoned.
Looks like the tailstock end is pretty well centered, why not flip it around and use the tailstock mark to remount the blank. Even if you have to taper towards the tailstock to get it balanced up there's enough there to still get your design out of I think
