Things that "turn" up
HOJ
21 Oct 2014
South Norfolk
So the request is to make 4 new capitals for some wooden columns, this is the sample I was given:
Some of it hasn't been eaten, enough to make a plan:
The scale:
The plan, at this stage, is to laminate pieces together (vertical) to make up the volume (I'll use bigger sections) which won't give me end grain as such:
I have 155mm over my lathe bed, so will just fit, without the square section though.
By the way, I don't do much wood turning so this will be a massive learning curve.
Richard Findley does quite a bit of this sort is stuff. If you can find some of his videos there's a lot of good information about glueing up multiple pieces for a project.
Looks interesting and hope to see some finished pics
I made some similar to that a little while back and I think slightly larger diameter. I used Iroko because the modern fast growing pine won't last anywhere near as long as the original stuff.
The scale:
Curious, I am guessing you are reproducing this capital on a T & M (time plus materials). If you were to give a price would you double your estimated cost ? To cover your you know what.
