Hello all
After much searching for a cheaper alternative to the MFT/3, for use with my Mafell MT55 track saw, I discovered MFSlab. My 25mm m.r. mdf is in the cnc shop at the moment.
I plan on getting dogs, rail guides and fence from UK bench dogs.
The table is approx 5ft x 3ft and 20.1mm diameter dog holes, at 96mm centres.
Need the saw horses now, although I'm not certain of whether to use saw horses or a fixed base (with castors to move around shop) as this will rarely leave my workshop.
Just wondering if anybody has an MFSlab or even an alternate MFT3 and what way did you build the base? Also, it seems UK bench dogs are the only source for mafell track dogs, at least where no modification of festool/makita is required, is this correct? UK bench dogs look pretty well made though so i may just proceed with ordering all from there.
