Deadeye":1jy6u0rq said:
+1 for this. Plastic pipe is as little as £2.50/m - so about 6m for the price of a 9mm MDF sheet. If you're ducts are 100mm square, a sheet will do 7.2m (and that's ignoring kerf loss)...
You can get steel spiral ducting for about £3.50-£4.00/m, where they nail you on the money is for bends, blast gates, and saddles.
Say TWW wanted a run of pipe along one 18ft wall and an 8ft wall, 3 lengths of 3m pipe would do that for about £33 from
Dust Spares, obviously you'd want a 90 degree bend in the corner so that's another £5, for arguments sake he plans on using the extraction line on 2 machines and a sanding station, he'd need 3 saddles at £15 a pop and probably another length of pipe at £11, He'd also want 3 blast gates at £16 each. A couple of end caps at £5 each as well and you're £152 into a top-grade extraction line. Obviously, there would be Flexi-hoses and the like added onto the price again but you'd need these with anything else anyway.
It sounds like a lot of money but really it doesn't really lose much value, pipes are pipes and fittings are fittings at the end of the day. Also quite easy to adapt and re-use the pipes elsewhere if you expand at all etc... Once you cut up the MDF for the ducting it's instantly worthless.
