That looks solid! Where was the pivot/angle bracket(s) from? And presumably it locates on the t-track under the rail rib? Thanks! P
Hi Peter
The pivot is a Bosch Rexroth swivel bearing.
https://www.aluminium-profile.co.uk/80-swivel-bearing-3842532209
The angles are cut and drilled by myself to suit these sliders.
https://www.aluminium-profile.co.uk/slider-kjn530329
I ground down this slide block then drilled and tapped it to suit the top plate that bolts to pivot.
https://www.aluminium-profile.co.uk/slide-block-1500mm-kjn510078
The landing side has a m5 bolt to locate the rail, I think that it needs changing to something to stop the rail wearing out or a slop stop but can’t seen to find one from the uk.
I had the back plate cnc by a water jet but I would get it cnc milled next time as water jet doesn’t give the cleanest cut.
In total cost around £300 in parts and labor
Curt
