So, finally did some planing of the 34mm boards, and first few were great, retained most of the thickness and was able to resaw a couple of smaller ones.
Then when edging one I was in the zone and only realised after a minute that I had tapered the board without ever getting a full pass on the edge.
One end had 1cm removed and the other none. Perhaps the board was concave along the edge?
The board is 18" and so shorter than both the beds.
I then decided to check setup again and found that although i'd aligned the beds (using spirit level), they were quite out, more so on one side.
Using my newer and better veritas straight edge, I went through the very difficult process of aligning. I am not sure about others, but on the scheppach you have to loosen 4 hard to reach bolts, lift the table to position and then tighten whilst lifting. Why there can't be levelling feet or some other simple mechanism I am not sure.
I did loosen only slightly, ant try with rubber mallet, for final adjustment, and then the act of tightening shifts the table.
So it was slight tighten of one bolt, then check the four positions (two on each table) with feeler gauge, and then slight tighten next one etc. also raising and lower the infeed each time after it was fairly tight to check the effect of moving the tables.
One side, one hour. Next side, thirty minutes.
Put everything back together, checking all the time.
Put fence on, and one table is square, other not.check again, have gap on one side that is quite significant!
After repeated checking each slight tighten of every nut i was pretty peeved... And that's where it is...
I also noted before it went out of alignment again, that with straight edge straight along table, i could not get a 0.05 feeler gauge under any of the four points which are extreme ends and the mouth.
However on a diagonal there were always gaps. Not sure how this can be, when it's straight across and along in all places!
Also on infeed on fence side I notice that a straight edge from end to mouth allows a 0.08 gauge under two thirds of it's length, and quite close to mouth.
Not sure if that's significant, and not much I can do about it anyway.
Some days can be very frustrating!
