woodbloke":3sy6p6d5 said:
A very good treatise on oil polishing is to be found in Alan Peter's book,
Cabinet Making, the Professional Approach', now out of print.
Use a solution of 50% raw linseed oil and white spirit, applied liberally over of many days until the timber no longer absorbs the oil.
I tried this method on a large oak coffee table top and it produced a fantastic finish which was impervious to almost everything except a lighted *** but it took about three or four months to finish and absorbed over a quart of oil!
This is the way that wooden boats are "impregnated" over here. Really impregnated with linseed oil, as oil is applied as long as the wood possibly is taking it. I've been impregnating a 12-metre long "Storbåt", which took about 250 litres of linseed, half a barrel of pine turpentine and the same of tar. 60+ applications over a period of 3 months. A small (row)boat can be impregnated by throwing in a bucket or two of oil and sloshing it around until the oil starts coming straight through the planking, which takes a week or so. So a full quart goes to your overalls only
I'm using linseed as a part of almost all finishes. It's not a good finish, but it makes a great lustre in the wood under the final coats. As just an oiled surface... nope. Just for breadboards or small pretty things standing on the mantelpiece. But under oil based varnish, shellac, wax, everything. And there is no need of waiting it to dry. Oil based varnish will just bond nicely if the first coat is applied to a fresh oil surface. It just takes a bit longer to cure. Shellac can be applied straight over a wiped surface as well. And wax, of course.
My basic finish is just two-three coats of linseed, short wait, two-three coats of shellac, wait, rub with 000 steel wool and a home-brewn wax made from beeswax, pine turps, pine tar, linseed oil. It takes half a day to do a good sized bookshelf and if you use proper furniture oil to wipe the shelf once or twice a year it also stays good looking. Can't tell for longer time than 10+ years, but at least that long.
Pekka
P:S,
Alf":3sy6p6d5 said:
Mr_Grimsdale":3sy6p6d5 said:
...linseed......on metal as a rust preventer...
There speaks someone who hasn't had to remove the stuff again after it's been on for 40 years or so. Nasty, sticky, evil stuff - picking it all off this #46 by hand was more than enough to convince me I'd shoot the next person I saw doing it...
Before slinging your revolver and wasting a bullet, please consider spending the same money to old style soft soap. Probably any kind of liquid soap would work, but old style soft lye soap (potash soap, I don't know and the dictionary won't help me either) seems to work best.
They used lye to remove paint, right? And lye soap is just oil added to the lye. So, the linseed gummed to the surface is just mixing with the lye left in the soap. Or at least that way I've figured it out, but it really works.
It's a really mild "paint stripper" and I guess any alkaline liquid soap might do the same trick.
