Hey Derek--good to see you around here more...
I have honed my Blue Spruce once since receiving it. If I wasn't date challenged, I would know how long that was
Paring for the back's mortise and squaring the hole for the bolt's square shoulder isn't exactly a challenge for a chisel, but it is similar to paring cuts for DTs and other joints.
I have cleaned up 30/40 or so DTs in some Peruvian Walnut, which isn't a demanding wood. And I typically saw the waste out of a joint with a coping saw, so they were truly paring cuts.
Would I bash this chisel? Probably not because it's got a Cocobolo handle. There also is no shoulder per se on the shaft. I do use light taps.
But I think this highlights the distinction of paring and bench chisels. I would never use any of my paring chisels--the Blue Spruce included--in place of a bench chisel. I may take some light paring cuts with the bench chisels if it was in my hand, but not the other way 'round.
I also use BB's angles for my paring chisels--the dreaded Sorbys :lol:
Oh, one more thing. The wood one typically uses also should be taken into consideration. If all I pared was softer hardwoods or softwood, I too would lower the bevel angles. I haven't gotten so far down the slope I have two sets of paring and bench chisels for hard or soft woods...
Take care, Mike
