Farmer Giles
The biggest tool in the box
Thanks Bob. I did read the instructions on line before buying the plate and decided I wanted to route it out as a slip with a forstner bit is possible as I couldn't get the table under a drill press, too deep. It didn't take long, but a lot of sawdust, the extraction on the DW isn't that good. I know the trick where you clamp scrap on two side of the forstner but I have still had inaccurate cuts with that if doing it by hand. The routing method is infallible, well nearly :lol:
Last update before beer O'clock. I have set it up to router the fence t-slots in the morning. The pipe clamps hold on some scrap at the far end so I can measure the cut before applying it to the top and stop break out. The two bits of wood clamped to the t-slots stop the router going any further than the centre line that goes through the router bit in the table. I have set it up identically both sides so I can route one slot, then the other before making adjustments for the next cut. So they will both be identically right or identically wrong
I shall double check all the measurements and set the end stops in the morning.
Andy
Andy
