So today I was going to jump in and route all the tracks and plate holes starting with the mitre track. I was following the table that "stuffimade" created
here and on youtube where he used the mitre/T track to hold down the MDF router template. Not essential but a good idea.
However I have cause for thought so may leave the mitre track to last as I am not convinced of the ideal placement. So far I have placed it half way between the centre of the router plate and the edge of the table, so not very scientific. It is currently 225mm from the edge and 225mm from the router bit.
I bought two different commercial feather-boards, for attaching to fence for downward pressure or in the mitre/T track for horizontal pressure. I can make my own but thought I would consider the placement of the mitre/T track with these first. This shows the orange Bench Dog feather-board that sits in the mitre track next to the red Wood Pecker hat fits in the T track. As you can see, with my current placement they are way back from the router bit so for thin stock you would need a packer, or a DIY feather board.
Then I checked out the mitre I have. It's an Incra that I bought after one or two more beers than I should have
It was a bit more than I wanted to pay but thought I could use it on several machines so buy well buy once. Looking at it as it moves from right to left, assuming you are pushing the work, there is plenty of adjustment as you can see here.
However when moving it from left to right there is a bolt that locks the fence extension that gets in the way so the mitre has a minimum distance from the router bit. At least if you don't replace the mitre fence with a bit of ply and t-track or similar. I have marked the bolt.
This bolt locks the extending fence like this
So I have a mitre fence that ideally wants the mitre track a little further from the router bit and feather-boards that ideally want it a bit closer. I can pack thin stock and leave the mitre slot where it is intended or move it closer so I can use the feather-boards directly on the stock then replace the fence on the mitre if used in the left to right direction. Decisions decisions!. I could always add another mitre slot too.
Here's the two side by side for comparison with the mitre fence moved just a bit closer to the router.
Thoughts welcome, however I will route the T slots for the router fence and the plate hole first while I contemplate..........
I am going out with the family today so may choose another workshop job instead and do this on Wednesday when I have a whole workshop day - yippee!
Andy
