Consistent rips on panel saw
I rip the makers edge off of the 22mm sheet and then push the new good edge up to the rip fence and use the sliding bed to push the sheet through. I set my rails and styles 3mm over sized and then put them through my thicknesser to the desired size making sure that it all stays consistent.
I'm ok with this method as it will product the level of quality I'm aiming for and probably still faster than setting up the track saw for every cut.
Doing perfect rips on a panel saw is not as easy as it sounds.
Typically you have the fence at the front of the sliding carriage and leave it like that for all cuts.
1) Put your 2440 x 1220 board on the saw, cut in half length ways
2) adjust rip fence to suit your experience, either set it so it extends beyond the back of the saw, or bring it forward so it finishes to the back of saw blade gullet - experience will tell you what works best for you.
3) slide your half sheet across so it hit the rip fence and push it forward so it hits cross cut fence
4) make your cut but bear in mind these points
a. Rip fence must be dead parallel to sliding carriage
b. rip fence must be dead straight - no bows in it’s length
c. riving knife must be dead central
If any of those aren’t perfect, you will struggle to keep your rip perfect, the board will creep away from the fence and when you push it back you will get a saw ‘divot’
In my experience panel saws don’t produce perfect rips, so get the best setup you can then sand the inner edge of your your shaker stiles and rails before assembly.
Twice in this thread it's been mentioned about having the crosscut fence at the front of the slider (infeed side?).
I never seem to see anyone using a slider this way, even any manufacturers images of their saws show it on the outfeed side so it's an interesting perspective to explore.
Also good to hear that they are not necessarily the best tool to do rips like this and it's not just me.
Really interesting thread. I dont do a lot of work cutting sheet goods but I've never really mastered ripping in this situation. My workaround is simply rough rip to slightly oversize and then do a final trim off the rip fence. Clearly not efficient but it works. Having read this I might have a tinker and set up the rip fence and carriage to run perfectly parallel with the blade. Got a kitchen to build in due course so would be nice to get this technique spot on
Cutting a load of rips then planing and thicknessing wouldn't be terribly inefficient, especially if you batched them. Not any different from using real timber.
I always use my saw that way around when possible as you have the support block on the fence helping avoid breakout. Due to the way my Felder is set up can only get around 3' of travel like that so have to swop fence onto outfeed when needing greater capacity.
I’m not sure if I’ve explained the setup correctly, my apologies.
The crosscut fence on a panel saw normally sits at “outfeed side”
It’s done like this so when sliding on sheet material you push the sheet up to the cross cut fence - you often need to lock the carriage so you can push it tight to the fence without it sliding away from you.
"The crosscut fence on a panel saw normally sits at “outfeed side”"
Yes and no. Depends what you're doing.
"It’s done like this so when sliding on sheet material you push the sheet up to the cross cut fence - you often need to lock the carriage so you can push it tight to the fence without it sliding away from you."
You can push the sheet (MDF, ply, OSB, etc) up to the fence from both the front and the back. So, if the fence and outrigger is at the back, slide the table all the way back and push the sheet up to the fence from the front, and if the the fence and outrigger are at the front push the table all the way forward and push sheet up to the fence from the back. Adjust position of the board for stops as required after that. Slainte.
In a previous life as a P.O.S shopfitting monkey I cannot hazard a guess to how many sheets of MDF I've full length strip ripped on my own.
Rightly or wrongly this was how I did it on large panel saws.
Always had the cross cut fence set forward on the outrigger and the outrigger all the way forward enough to leave room at the end of the sliding table to allow me to grip the table handle and push the sheet with my body/other hand. This allowed for a simple movement to position myself to push the sheet up to the fence for the next rip.
If the work was the other side of the cross cut fence I would have had to go around it and move the sheet over.
The 4ft fence was right back to the gullets of the blade to avoid the cut piece getting trapped and launching it's way off down the workshop and embedding itself in the canteen door !! Yes it was me.
Riving knife was always 100% in line with the blade.
Cross cut fence always set to cut 90 degrees from the nearside and regularly checked by cutting and rotating to ensure the 5th cut was exactly the same as the first.
Cheers, Andy
Yes I should have qualified what I said in terms of its position when used for cutting sheets and I agree with what you say: "it depends"
certainly for a hobbyist it may pay to move the outrigger position on the slider, but in industry it hardly ever gets moved
Ive worked in joinery for decades in various businesses and almost never have I seen anybody alter the position of the outrigger crosscut fence -and thats for either cutting timber or sheet material
Ive cut thousands of timber parts on a panel saw like this and it works totally fine, it can get a bit tiring though as you have to keep the pressure on the timber
I think it's true to say that we've both had considerable experience using sliding table saws along with a host of other industrial machinery. I've been aware for a long time of the good knowledge regarding woodworking you bring to this forum: I'm much less sure about what you bring to the off-topic section though, but I mostly only intermittently browse political threads, or other similarly controversial topics preferring to express almost no opinion in any of them, ha, ha.
My experience of sliding table saws does evidently rather differ to yours in that it has always been the case that the outrigger and fence are set at the back for probably 30 - 40% of all the tasks undertaken. I suspect that may be down to the majority of my work being focused on craft furniture rather than, say, mostly flat panel processing and manufacture. I'm aware of many sliding table saws having the outrigger and fence almost exclusively set at the front end as you describe, but that doesn't match my experience. Slainte.
