Phil Pascoe
Best thing I ever got rid of. My bench has always had a well - up til this house move and I needed to make it narrower. So much better without one.
I think you will find it's a feature of a traditional joiners bench thoughIt's not a tradition it's just a useful feature - it traps not only dust and rubbish but also tools and other bits and bobs being used, which could get in the way of the work going on above them.
It's also easier to keep flat if you happen to be a flatness fetishist.
Presuming you cannot have the bench anywhere else,I have nowhere to put tools when there's no well, how do you cope?
island bench? my entire space is way too small for that, would be nice to be able to do that though.Presuming you cannot have the bench anywhere else,
Very nice to having tools right behind you if you can fit an island bench, more access and light on the work.
I notice this sometimes when moving my bench around, and ultimately end up back again to where it was after a bit of tetris, as there is shadows and whatnot elsewhere around the floor.
Related, though unrelated.
In this vid by Peter Sellers(all hail) i notice that he's used what looks like ply to infill the void in those alloy sash cramps. Obviously this is to strengthen and add rigidity.
I've a number of these clamps, i got them years ago and while i havent really had any issues with them, i think thats a very good idea.
Seems to be a few different opinions on squeeze out(unsurprisingly) some wipe it off while still wet*, some wait till its 'skinned over' so not hard and then use a chisel or scraper to take it off and some allow it to fully cure then plane it off.Out of interest, can I plane over the squeeze-out from gluing up, or should I try and gently chisel the worst of it off first?
For my bench top I just planed it off, but then read it could damage the plane iron.. and the laminated aprons etc still need doing but have dried already. Thanks for your response btwSeems to be a few different opinions on squeeze out(unsurprisingly) some wipe it off while still wet*, some wait till its 'skinned over' so not hard and then use a chisel or scraper to take it off and some allow it to fully cure then plane it off.
Dried glue is pretty hard stuff and can in my opinion through observation cause chipping on surface planer blades.
* If you understand surface tension of water, most wood glues being water based, if you using a damp cloth wipe away the excess, as it dries it can pull back from the edge leaving the edge of jointed components devoid of glue, which is usually unsightly and obviously not actually glued up.
Personally i like to leave it till its skinned over and still slightly soft before using an older chisel or scraper to remove it. But each to their own.
