Jonm
In a recent post problems with the kitty bandsaw came up, see links below.
I have a kitty 513 which seems to be identical to the 613. Cannot get on with it. Nothing seems damaged or worn but the blade will not stay on the wheels. I have taken the table off, used a rigid straight edge with wooden blocks to get the wheels in line, checked with the blade tensioned. Have adjusted the bottom wheel as well. Nothing seems to work.
I am using the blade which came with the machine, plan was to get it working then buy some tuffsaw blades. I am wondering if there is a problem with the blade. My other thought is that these saws have flat wheels so the blade is positioned with the teeth overhanging the edge of the wheel. Perhaps the more normal crowned wheels have a self centring effect.
It would appear that other members have had problems with these machines and I am asking if anyone else has any experience of these machines, good or bad and if there is something needed in the setup to get them working.
Garden Shed Projects
Linwoodjoinery
I am pretty frustrated with mine. I expected it to be as easy to use as the OP suggested but find it very difficult to set up. Thinking of selling it to maybe buy a different make. It’s a Kity 613.
Linwoodjoinery
Agree with jonm and garden shed projects. I had a Kity too and whatever I did or tried I could not get in with it. Spent hours and in the end got rid of it. Having only previously used big old cast band saws before this I was left disappointed with the Kity. Which is a shame as I have had other Kity machines which have been superb.
