user 36867
- Joined
- 23 Apr 2021
- Messages
- 193
- Reaction score
- 80
That's pretty similar in principle to the technique I was referring to, albeit that method used some cord to pull the last bit on, I guess anything that is thin and that doesn't damage the tyre would work and which can be removed once the tyre is fully on.I’ve also got the tyres for the saw though I haven’t fitted them yet.
This is a video of the recommended fitting procedure though I’m not sure it the best, let me know if it doesn’t work for you and I’ll put up a YouTube video
There's a whole lot more free play in that one than there is on mine. There was vid. posted here a while back with a bolt of some kind with nuts and a washer that in a power drill that worked for me.I’ve also got the tyres for the saw though I haven’t fitted them yet.
Would you like to be more clear or link to the post or give some key words so I can search.There's a whole lot more free play in that one than there is on mine. There was vid. posted here a while back with a bolt of some kind with nuts and a washer that in a power drill that worked for me.
Thanks for that, lt certainly looks to be reasonably easyHere you go. By far the easiest method I have come across. I used cable ties instead of string.
I spoke way too soon ;(. Probably with a ½” neoprene belt it’s easy, with a ¾” neoprene belt probably not difficult.Thanks for that, lt certainly looks to be reasonably easy
I don’t know if there is any interest in what is available in Thailand.
I just took delivery of a 16” bandsaw that cost ฿29,000 or about £650
As you can see is a very basic machine and it will blow 13A fuses on starting
It doesn’t even have tyres on the wheels so is remarkably noisy, I think, at 80db~90db
I am going to upgrade it & if there is any interest I will post a longer review along with everything I’m going to do.
I already have some items coming, they include a better rip fence (฿4,142), rubber tyres ($20.59) and a TCT blade 2,921mm x 20mm (36.82)
Comments will determine if I should continue posting.
Didn’t you read any of the information on the BigWood site?Big Wood looks like rebadged Harvey/Axminster/Itech/ etc.. Likely the same manufacturer in China.
OK my B-i-L assisted with the bottom tyre. With 2 people the install was very much easier, the changes in procedure were to first use a bigger water container, second keep the tyre in the hot water for 2 minutes, then having stretched the tyre both of us proceeded to use the drill idea to put the tyre on, this probably took less than 5 minutes, though when first running the wheel it was clear that I needed to even out the tension on the tyre as it was noticeable that it was narrowed in one area, so I ran the drill round the wheel a few times. This was successful.So 1 tyre on the top belt for today. I’ll get my brother-in-law to assist with the bottom when he is next here.
The kerf at 1.8mm was influenced by at least 1 tooth that was bent, it was beside the weld so may have been a manufacturing defect. I have bent it back and am down to 1.5mm.The kurf of the blade seems to be about 1.8mm though it’s claimed to be 0.9mm. It’s late and I haven’t got the time or materials handy to do more than the first short sample cut so that’s not at all definitive.
