I mitred the little panel trim mouldings and glued them into place:
The rest of this post is about something I've not done before. I wanted a cornice for the top of the unit, and not having a spindle moulder my only option (other than phone a friend) was to hand plane the pieces. A friend had given me a hollowing plane (I guess a boat builder might call it a backing out plane, maybe) last year, but I'd never used it:
This is a rough idea of what I was aiming at (the one on the right):
Sharpening it was easy (blade seemed a little soft), but a few experiments on scraps quickly showed me that it isn't easily "steerable". You can hack off quite a lot of wood in the wrong place in something of a hurry. I soon worked out that running it in grooves was the best way. So, this is what I did on the router table:
So that's a couple of chamfers, not quite meeting, along the edges, and a series of straight grooves run along the length of the face.
Workholding, without a tail vice, involved a wedge and a screwed down back stop:
It took quite a while to get to grips with the plane settings. It went from not cutting at all to gouging out chunks with the tiniest of taps, but in the end, I got the hang of it:
I found it useful to smooth off the worst of the edge marks with 40 grit paper on a quick sanding block:
Then back to the plane for a final shaping, check with a little ply template, and sand with 100 grit, before finishing the chamfers on the planer.
There's a way to while away a couple of hours. What, 10 minutes on a spindle moulder, maybe? And I fully expect to have to do some adjustments when I start mitre-ing (
how do you spell that?) these bits together sometime in the next few days. That was sweaty work today, but despite a couple of bashed knuckles I am fairly pleased to have acquired a new technique.
