Paul Kierstead
dchenard":sydv5784 said:Are you a psychologist also? So many talents... =D>
Why, thank you. \/
Paul Kierstead":3fykstsj said:dchenard":3fykstsj said:Are you a psychologist also? So many talents... =D>
Why, thank you. \/
dchenard":22rggfw8 said:And I would NEVER attempt tweaking a straightedge...
Paul Kierstead":27qldiuj said:dchenard":27qldiuj said:And I would NEVER attempt tweaking a straightedge...
But do you ever check it? It isn't that hard. Conceptually they are pretty easy to make, too (though look like a lot of work). They do go off after a while, especially if used around the shop. The point I was making is that you check your planes, chisels, squares, etc; probably most tools in the shop. A pair of winding sticks is pretty minor and easy to check too.
dchenard":3m5d3hi8 said:We're talking here about a steel straightedge guaranteed to be precise to 0.001" over its length (and stay that way), not a homemade one.
Paul Kierstead":1cucwge8 said:dchenard":1cucwge8 said:We're talking here about a steel straightedge guaranteed to be precise to 0.001" over its length (and stay that way), not a homemade one.
Show me the one guranteed to stay that way.
the Aussie board has some good ones too.....'course you have to stand on your head to see 'em properly....
dchenard":2he64qss said:Cheaper, that's only if you don't value your time... I do for mine, so I bought the LV sticks. You wouldnt believe who I had to convince that it was a good buy... :shock:
DC
Well, erm, the LV sticks aren't exactly much of a step up from alu angle really, are they? 8-[Roger Nixon":js81a5fc said:In the meantime, I'm still using pieces of aluminum angle.
