Robert Sorby Proedge tilting table bolts
Chickpea
22 Jun 2020
Ely
Hi all,
I have a Sorby Proedge, and want to replace one of the 2 bolts that secure the tilting table.
They are M8 x 20 countersunk bolts but have quite a large diameter head that's around 15mm across. I guess standard countersunk bolts will hold, but was wondering if anyone knows a supplier of larger head diameter countersunk bolts.
I have enclosed a photo and it's the bolt at the bottom that I'm after.
Many thanks,
Richard
    2.5 MB
Hi all,
Many thanks,
Richard
This from Toolstation seems it might do, just cut to length and file off the flats near the head
cheers
Coach Bolt & Nut M8 x 65​
by UnbrandedProduct Code: 84392
Unbranded
Accu might well, and they are happy to supply singles.
When you put 'm8 countersunk bolt dimensions' into a Google near you, it helpfully gives you some diagrams and measurements of bolts. If you care to look up M8 on those diagrams, you would see that the standard countersink head is 16mm in diameter. Thus, you should verify your "around" 15mm and consider _reducing_ the head of a standard bolt if that dimension is confirmed.
I have no idea why you would be seeking larger head bolts in this situation.
Unless you have already removed one of the bolts and know this to be true, be prepared for it to be retained by threadlock (loctite). If exerting reasonable force on the allen key does not shift it, do not resort to unreasonable force or you will strip the head. Instead, heat the bolt well with a small blowtorch to denature the thread lock and then try again.
