' The very best' ..... I don't know about that. but thanks.
Anyhow, how you all going ? ..sorry its been so long for me to reply. Busy week.
Honestly, I look at that knockoff stanley of mine now and I get embarrised at its appearence.
What Mike said rings a bell.
The idea of skewing the blade like thats been around for a while....there's that stanley version of it I've forgotten the number of....Somewhere in here I think...
http://www.supertool.com/StanleyBG/stan0a.html ...
#51 ?
but on end grain, quite unlike accross grain, I don't think the improvements as great as I thought it would be......I mean, you can quite easily shoot with any square bedded plane.
What I like about skewed blade, really is just that you can often start a pass slowly, ......kind of ease into and out of a pass....ie. often I've found you don't have to whip the plane in at full speed to complete the cut...
but really the cut made by a skewed blade on end grain doesn't seem to leave a finish any better than a normal one if the blades are sharp.
So, I don't really think there is any ideal angle to skew the blade at. From that old post theres that knockoff stanley with a plate attached, and a wooden plane(badger ?).
The knockoff's blade is skewed just slightly, and the old wooden ones tilts far more.....They both perform similarily shooting mitres, though the wooden one feels nicer to use this way. But when shooting square the wooden one jumps if you don't pressure down properly like Mike mentioned with thick timber....thats when the heavier knockoff, with all that metal and less skew seems to better.
But, these planes of mine have a couple of problems thats worth remembering.
1. If the timber your shooting is thinner than say about 10mm then problems begin.....So, I can see how a bevel up plane and a close mouth would improve on my scruffy looking planes. I wrote a thread on it...
http://www.woodworkforums.ubeaut.com.au ... hp?t=30859
2. my planes are adjusted by hammer taps. Well, unlike adjustment for regular bench work, this can cause a problem on the shooting board.......you know how you have to 'run in ' a shooting board....well, its hard not to on occation to set a blade to cut too coarsely and inadvertantly take too great a shaving.....which will permanently run the fence in for that sort of shaving...only needs to happen once....which means the fence won't support the lagging corner of your work well when you take a normal thinner shaving....leaving a little dag or tear .......more modern planes with there laterial and depth adjusters seem less prone to this happening.
Can fix it by screwing on a new fence and running that in. but its a bit of a PITA.
What you say about reduced wear to blade with ramped shooting board sounds right. Personally don't know if I'd bother going to the effort to make up a ramp. But we're all different eh. I often just shim up the board I'm shooting with planks to present my shoot to a fresh part of the blade. Same sort of thing......but the idea seems good alright.
From what I've learn't so far, for those who can't afford dedicated shooting planes or bevel up planes etc, I'd recommend shooting with a plane with less height when its on its side, like a #3 stanley bench plane. Less likely to wobble about......its unlikely I think, that you'll find use for a wider blade anyway. There's a definete limit to how thick a timber you can shoot anyway. I rarely bother trying to shoot timbers any thicker than about 1", and that well within the scope of a #3's blade. If you know what I mean.
I'd definetly install whatever plane you use with a thick blade though(end grains hard...chatter etc), a fine setting and a very closely set mouth. End grain shavings don't jam up as easily as with grain shavings, so you might as well keep it tight, for planing thin stock. ...suspect keeping it tight helps the finish a little too....but not much. IMO. ......but having said that, you can live without these last points. I have been for years with my shooting planes. If the blades sharp, you can often get away with anything I've found.
I betta shut up now. deary me, I do rave a lot.
