Charley
Do you ever have a job that appears to be nice and easy but once you start it creates 10 more?
Some of you may remember me saying that the electrics in the workshop are a joke. No CU, just a SWA coming in from the office on a very long and quite dodgy radial circuit.
Luckily we've got a sparky in the family. The plan was - in a few months - to rip everything out, plasterboard and insulate the ceiling, fit a CU, wire up the sockets, new lights, etc. But then now I've got a new table saw on the way (did I mention that? :wink: =P~ ) and ideally it needs it's own circuit, I thought that for the time being we could just install a CU and re-wire the existing sockets and lights so everything is safe and up to part P..
I started to trace the existing wires from the JB. One of the wires from the JB goes to a socket & looked dodgy as the outside light switch looked like it was being powered by a spur from the socket. I opened it up to have a look at the wires and the wire from the switch was connected directly to the terminals in the back of the socket :-s I've never really noticed it before and at the time wasn't sure what the switch, switched. (with me so far?
) As I had my mains tester screwdriver in my hand I went to check if the wires were live.... BANG.... a massive spark came out (like a welding spark/arc) :shock: [-o< :-k Luckily no harm to me although shocked to why it happened.
But I afraid my mains tester took a hit:
click image to enlarge
(homer) hmmmmm Meeellltted
Adam (moderator Adam) said it could of been dodgy wiring, a fault with the outside light or even the mains tester that caused the short.
So really the sooner I get it re-wired, the better [-o<
I went back into the workshop to finish tracing the wires and from the socket that just shorted there's another socket and switch, then two wires go down the wall into the floor & then into the inspection pit. I knew one was for a light and I assumed there must be a socket in there as well. I opened the inspection pit to make sure the where the wire went ....
Well I think I've found out why the socket shorted and melted my tester :idea: ........ DAMP #-o the bottom of the pit is filled with water
about 10cm deep. The walls are wet through even at the top, the underneath of the wooden lids are soaking and judging by the marks on the wall the water has been about 5ft deep at one stage :shock:
So the good news is I've found out why the socket sparked on me - the bad news is I've got to hire a pump and then work out where the water is coming from... Might explain our high water bills :roll: :lol:
You never know it could be the next Peckham Spring \
![](https://proxy.imagearchive.com/6a5/6a5c75628630fdb7edfebd196a37e96e.jpg)
![](https://proxy.imagearchive.com/9f5/9f5188d5a8ca22464363b8a7871085ae.jpg)
![](https://proxy.imagearchive.com/2d6/2d692db53133f09ec60b71064b6519d4.jpg)
![](https://proxy.imagearchive.com/e73/e73ec39347bdef37021453088bb16747.jpg)
