There is a downside to having neons on the fused spurs. My late MiL had severe dementia and every twenty minutes she would tell me that "I had left everything on"!
My wife doesn’t have dementia but is forever going on about standby led and neons on switches. I resorted to taping over the leds on my computers.There is a downside to having neons on the fused spurs. My late MiL had severe dementia and every twenty minutes she would tell me that "I had left everything on"!
Our isolating switches are hiding behind the microwave.There is a downside to having neons on the fused spurs. My late MiL had severe dementia and every twenty minutes she would tell me that "I had left everything on"!
But not if the switch is on a 2x2.5mm ring main fed from a 30A breaker and steps down to a single 2.5 t&e from switch to socket.Sockets below worktops should be controlled by a 20a switch above not a FCU as that adds an unnecessary fuse.
I wish I could teach my cat to close the back door when she comes in - she pushes it open from outside!I just wish I could teach my wife to close the back door, heating on, back door open when she goes to the bins, appalling waste of energy, I don't do bins too busy building stuff.
In our house, the oscillator is referred to as "the cat flap tool".I wish I could teach my cat to close the back door when she comes in - she pushes it open from outside!![]()
The very concept of spurs and ring mains is at best questionable. On the one hand you have the ring protected by a 32 amp protective device but you can take an unfused spur from any socket using 2.5mm T&E . The reason for the fuse in the plug is because there will be a change in current capacity between the ring and the load being connected, you can also read that as a change in cable size. With a radial circuit run in 2.5mm cable you use a 20 amp protective device so with the spur taken from the ring you will have a cable that with a type B 32 amp mcb will potentially need to handle three times rated current during a fault condition.Sockets below worktops should be controlled by a 20a switch above not a FCU as that adds an unnecessary fuse.
Only if using reference method C, ie clipped direct which is 27 amps but once enclosed then you derate the cable .But the single t&e will be rated at 26a.
Ever tried teaching a cat to use multitool?In our house, the oscillator is referred to as "the cat flap tool".
We got so fed up of the cats pushing the inside doors open and making draughts that we fitted cat flaps in a couple of the internal doors as well as the back door.
A multitool is awesome for cutting in a catflap....
My boxer used to let herself out through an inward opening external door.I wish I could teach my cat to close the back door when she comes in - she pushes it open from outside!![]()
