SammyQ
I'm shamelessly aiming this at MikeG. - and any other architects or knowledgeable builders hereon - if he or they want to fulminate and castigate me for shameless cadging (consultation in sheeps' clothing?), please feel free; I'm operating on the principle 'you can only ask, even if you get turned down'...
Scenario: I am 62, a retired teacher, with that profession's pension as my sole income for the next four years. I have just moved/downsized house, to N.E. England , just above Newcastle. It has a detached sectional concrete garage, 16' x 8' in old money, with a pitched, corrugated concrete roof, looking suspiciously like asbestos sheeting. I want to line/insulate the beast to have a proper workshop for the first time in my life, but keeping fiscal outlay to an absolute minimum and physical labour similarly minimal, for other reasons. I have several vulnerable machines: a Wadkin AGS, a Crescent-clone bandsaw, planer/thicknesser, two dust extractors, a gurt big floor drill and numerous (but enough Mike!) hand tools all vulnerable to tinworm in the presently damp conditions in there. It's condensation for sure, for sure, brought on by weather change and my heavy breathing...
on the (now) cold under-surface of the roof. Floor, walls and ceiling are all sealed, including gaps under corrugation 'peaks'; don't know that they could be called "eaves"?
Query: I've read oodles online about the dire potentials of asbestos roofing. But...mine isn't leaking and appears to be in good nick (photos later)...is there any GOOD, SCIENTIFICALLY VALID reason for not simply leaving it alone and sealing its underside - i.e. my proposed workshop ceiling? That would negate dust falling from its underside and giving me mesothelioma or worse. I'm thinking cellulite...sorry, Celotex, or similar; wedged, glued, SEALED, tight up against the lower surface of the corrugated material of the roof. This, I naively believe, might be called a 'warm roof'?? I reckon the foil backing would also count as an impervious layer? As, of course, would the expanded foam? I do not presently see any need to open up the sealed edges at the wall-roof junction, as I believe there is no need for air circulation in said 'warm roof'?
I also intend to smooth the rough concrete floor, then DPM it, batten out with metric 2" by 1" rough, 50mm Jablite/Celotex into the voids and lay a loose (floating) floor with 18mm T&G boarding, glued together on the joins. The THIN horizontal pre-cast sectional walls I propose to 'dot and dab' 50mm Celotex to, resting it on the flooring, left naked, save where I need to over-board with solid ply or other boarding to hang tools on etc. For that, I'll add floor to ceiling battens, to transfer load to the floor, rather than risk 'pullout' from the (apparently) 25-30mm panel thickness of the walls.
Sorry I have no photos presently, they are locked away in the attic on my PC while we complete work in the house. I will add phone photos, upon request, for clarification, if needed.
Have at it Lads...
Sam
Have at it Lads...
Sam
