Ok heres where i reference my prices from,
a tv cabinet for customer who's got more money than sense.
thats a 4ft wide plasma in there.
It was 8 weeks work & then 2 days install with myself & assistant(including 600 mile round trip delivery)--it's not my design thank goodness.
It was $28,000--with materials being in the $5,000 range,i used to have all the details(Bid breakdown)but lost them upon moving,the shop operated at $50 an hour,my boss was happy & the customer was happy,& boy was it a lot of work.Towards the end of the last 2 weeks i was tired of looking at it.
The thing about working off interior designer's prints is that invariably-you spend so much time making adjustments asking for details to be clarified ,that you might as well have redrawn the whole thing yourself,at the last minute i found out the plasma tv model had been changed months previously,the designer didn't think it was an important piece of info i needed,the internal frame surrounding the tv is the second i made at the last moment,speakers are behind the cloth frames(more nuttyness)& the whole thing had to have multiple holes in every cabinet for a/v wiring.
Next up is a veneered 60'" starburst tiger maple & rosewood table ---i made this for myself out of leftover veneers/wood upon closedown of my shop,It took six weeks to make --i like the table because its for me & i made it completely on the fly without a design worked out,it sort of developed as i was making it(quite an experiment & some brainstorming moments)the top is a 16 piece starburst tiger maple where i buggered up a little piece of the center so had to resort to a coverup with rosewood & ebony inlay,the edge detail is 2" thick with rosewood veneer wrapped around the curved edge,the column is coopered & turned mahogany with a taper & 2 ply veneer wrap (sapele/tiger maple), the base is solid poplar with rosewood veneer & solid ebony end caps,the whole thing holds together with a 3/4" steel pipe threaded each end that goes through the column into flange plate under the base with a large nut to tighten at the top & hold the base/column/underframe together as one unit,the top sits on the underframe,i had to make a custom 7' x 8' veneer bag/1"mdf platen to accommodate the 60"top every piece of veneer was done in the bag including the column & the base parts,the starburst was by far the most difficult thing i have ever attempted in woodworking & didn't quite come off, the mistake was pretty minor but with a starburst you can't get away with it
From a design point of view its far from perfect as basically i didn't have time to devote in the frantic rush to close down the shop,it was an image i had going around in my head for a while & i created it from thought rather than drawings--this fact i'm particulary proud of as it was pure judgement with no reference points apart from what i was holding in my head.Basically the table is completely veneered,It has no finish on it in pic(ran out of time at shop).In summary i'd say the design has a great 'thrown together' look vs a good design.Some slight changes in detail sizes would have balanced it out,& made it look more refined.Some things i did spot but was restricted by lack of materials,if i had those -it would look different.
another week for finishing will complete the damn thing.
my point here is that both of these items have a magnitude more work than those chest of drawers(which i might add he has probably made several of)which also makes me ask the question--however long did he take on the first example.
shivers.
fire away --go on crucify me --i probably deserve it anyway.
