Distinterior
I think all new W/M's now, only come with Cold Fill only.....I cant remember the last time I even came across a W/M with both hot & cold inlet pipes. They heat the water to the required temperature dictated by the program chosen.
As to the logic of whether to supply the machine with hot water rather than cold,......Domestic hot water in the UK should be supplied at 60/65 degrees optimally, so if you are only putting water in at this temperature, when you set your machine to run on a cooler temperature program, say 30 degrees for example for delicates,.......How is the machine going to reduce the incoming water temperature to suit the program you've chosen....??
