Eric The Viking
- Joined
- 19 Jan 2010
- Messages
- 6,599
- Reaction score
- 76
It looks like the wires are in the correct places, but, given the current required, those actual connections look nasty.
The bare copper ought to be properly grabbed (caught up) by the terminal post or at least a brass/plated washer on top. There is too much copper showing. I suspect either those connections or the cable or the other end (where it connects into the spur) are high enough resistance to limit the current (or drop the voltage, to express it t'other way round). That said, 2.5mmsq ought to be enough copper for this (in the cable), as 3kW is only roughly 13A.
A far better way to do it, both neater and electrically better, is to crimp eyes to the ends (either circular or U-shaped), and then attach those to the actual terminals. You need a properly set up crimp tool, but it's theoretically a better connection even than soldering.
I'd see if you can improve the connections in the hob, and/or the spur box too, just in case. If that doesn't do it, thicker cable might help. You could test that by doubling up the cable temporarily and doing your test again.
I agree with the other posters who've said the only variable is the hob. If you have used the same pan and the same amount of water, and you workshop one is supposedly lower power, yet the water boils in significantly shorter time, something isn't right.
