thankyou, this take some of the stress out of doing this for the first timeTry not to over think it, the best solution is the one that you have materials for. If you really want, you can use oak folding wedges.
It doesn't matter really.
Only reason I was thinking of shim was because I've never laid any brick before so I was thinking Ill take my time getting it all level with shims and then just pack out.Why do you need shims? Why can’t you just bed each end on a dryish
why do you need shims ? Why can’t you just bed each end on mortar and level up ? Also 50mm is too small really you should be looking at something similar to the width of the lintel and 150mm long at each end
50mm is a very small point load and although you may be pushing in extra mortar it’s the shims that will be taking the pressure also it’s better to use sharp/concreting sand to bed on as builders sand shrinks
But It would probably be quicker to just lay a strip or mortar and set each one down as i go. I just got some string and will need to get a string level, if i can get those setup maybe this is the way to go. Ive never done any of this before so a bit wary
