Edge jointing means joining up narrower pieces of wood to make a wider board. It's something you have to do with nearly all furniture projects, because most boards sold today are less than 300mm wide, and the majority are in the range 150-200mm wide. So if you want a table top, or a chair seat, or a panel for frame and panel work, then you'll have to learn to edge joint.
When it goes as planned it looks like this. You start with a board that has at least one true face, and you then cut an edge that's at
exactly 90 degrees to the reference face all along its length,
You also need this edge to be dead straight, or possibly with a
minute hollow in the centre, but on no account must it have any trace of a "bump" when tested with either a wooden or metal straight edge,
When you've repeated that process on a second board they should sit together
perfectly,
Which means when they're cramped for the glue up there's an invisible glue line and you can rest a straight edge across them, and the resulting table top (or panel, or whatever) is perfectly flat with no visible gap,
So, how do you set about doing this?
There are plenty of different approaches, but I'll take you through the approach I use, which I know is shared by many other cabinet makers.
I guess the first thing to say is that the very best glue lines will come from a sharp bench plane. With the right machinery you can produce a good edge straight from a machine,
But if you look carefully at a planed or sawn edge you'll still find traces of machine marks, these for example are the tell-tale ripples from a planer,
And that's from a good planer, where the knives are always kept sharp. But most hobbyists aren't in that position, they may have a planer with a fence that has a slight twist along it's length, or the knives are bit blunt, or it's prone to snipe. Or they may not have a planer at all, and be relying on a lunch box/bench top type thicknesser, or even just hand tools.
That shouldn't be a problem. For many years I had a small workshop that could only accommodate a bench top thicknesser and a band saw, yet I managed to produce plenty of edge jointed components to the highest standards. And with a bit of application so can you.
I've reached the photo limit for a single post, so I'll continue in the next post.
