El Barto
This is such a great topic so thanks Custard. My two pence to the process is that quality cramps really make such a difference to what is an already stressful process, especially for a newcomer.
When I built my workbench and had to laminate the top, I bought cheap aluminium sash cramps a la Paul Sellers and followed his advice about reinforcing them with wooden strips. In hindsight I would splash out for high or higher quality cramps if I could as the cheap ones are terrible. The heads frequently bind to the bar and the little rubber grommets on the handles fall off all the time - I found myself faffing about with making them work correctly instead of focussing on the glue up. So I think that's probably an area of the beginner woodworker's kit list that is often overlooked. I used them for a glue up tonight and they were utterly useless and so back into the corner they'll go.
However I did get a couple of these the other day and they have been very good and also reasonably priced: https://www.axminster.co.uk/axminster-t ... p-ax945578
Thanks again Custard.
