Nev Hallam
So what your telling me is to put a 60w bulb or energy saving equivalent in to a biscuit tin with holes in, with some kind of chimney attached?
Nev Hallam":3hhxev01 said:So what your telling me is to put a 60w bulb or energy saving equivalent in to a biscuit tin with holes in, with some kind of chimney attached?
9fingers":13f7nfrk said:It is so trivial to implement that it should be within the scope of anyone who can use machinery. The heaters need to be in intimate contact with the metal so every fit is machine specific which makes it difficult to market as a universal solution.
It has rather surprised me that I have had such limited response/questions about it since publishing it here quite sometime ago.
In my engineering workshop, I have a cupboard in which I keep my precision tools which has a metal rear panel with low power heaters on the back and insulation behind up against a wall. The inside of the cupboard and internal drawers stays gently warm and keeps rust away from micrometers, dial indicators and other precious instruments.
A little appliance of science works wonders!
Bob
9fingers":1kupcyn3 said:Nev, I did submit a reply earlier on to this thread but it seemed to get lost on the way to the forum.
I noticed the other day that Toolstation are selling seals to help seal garage type doors. If when you are able, you were to fit something like this and then heat your workshop that will be a good solution.
The scheme for heating the machine is best suited when whole volume heating is not practical/possible for some other reason.
You also mentioned paraffin heating. Unless you can take the flue outside, these heaters produce a lot of water vapour and are best avoided.
Good Luck for a rust free winter!
Bob
9fingers":3ewq1s5g said:It will still be less effective than doing the job properly.
We put a lot of effort into our woodworking projects to get optimum results why the reluctance to look after our tools/machines properly.
I just don't understand this???
Bob
Nev Hallam":2njfsq18 said:maybe we could just put our workshops in the house, possibly in the unused dining room spaces or the spare rooms!
Benchwayze":1172no3i said:That was in the days when bulbs didn't use as much power as is claimed today. 8) Therefore much less expensive than using paraffin or a proper heating element.
big soft moose":sbg8rm5o said:Benchwayze":sbg8rm5o said:That was in the days when bulbs didn't use as much power as is claimed today. 8) Therefore much less expensive than using paraffin or a proper heating element.
Huh - surely a 60W bulb requires 60W and always has done - its hard to see how they could have used less than 60W in the past yet remained 60W bulbs :duno:
as to the fire in your bedroom i would suggest that your bulb was deffective - I have an 18W energy saver in the 'shop and even after four or five hours it is still cool enough to hold in the hand - certainly you couldnt cook a chicken with that one
Tim Nott":3pjjjn5h said:My son and I just fitted a little woodburning stove, which was 'given' to us. It's not a turbo, but it burns all the scraps and sawdust. And it keeps us warm. I thing the workshop is around 70 cu m.
This site sells them, and works out how big you need. The flue stuff is expensive!
