kasandrich":22ic89pi said:
I would think you would be better off with a 2kw electric oil filled radiator and put it on frost protection.
I am not sure a couple of ordinary bulbs is enough for an uninsulated workshop that size.
How draughty is it?
A week or so ago, I watched a programme called 'Bang Goes The Science'. One of the presenters cooked a chicken to a tee, using two 60w tungsten bulbs, in an insulated oven. It took just 90 minutes apparently. This stunt was to prove how much heat was generated by a tungsten bulb.
It's true of course, and these bulbs generate a 'lorra-lorra' heat. One 60 watt bulb in a 'batten' lamp-holder, inside the case of an old paraffin stove, complete with chimney heated my single-car garage no problem. (A friend of mine used the idea for his greenhouse, with great results.)
That was in the days when bulbs didn't use as much power as is claimed today. 8) Therefore much less expensive than using paraffin or a proper heating element.
If you don't have an old paraffin stove, use a biscuit tin with a few holes in it and put a chimney over it.
(The presenter on the Science programme claimed it wasn't possible to cook a chicken with the new low energy bulbs. If that is the case, how did one of these bulbs almost start a fire in my bedroom, when it burned the hem of the curtains? )
In my experience, low energy bulbs get just as hot as the tungsten variety. I can't hold either in my hand when they have just been turned off. So you could probably use the same techs with the new bulbs, despite what that presenter claimed.
HTH
