Cottonwood
"so it becomes a question of what is being checked against what?"
Theres the rub (hammer) Its all relative.
Wiley Horne":22hb7l72 said:If you go to your local glass shop and get an off cut out of their shorts pile, it'll be float glass.
matt_southward":pi3e0r3j said:I received the scary sharp 'starter pack' from Workshop Heaven today (yes I know Matthew posts regularly here) and got out my Veritas straight edge to confirm the flatness of the float glass only to find that it's not flat. As far as I can see it 'crowns' in the middle and my best guess is that it's out on each corner by (in the order of) 0.25 to 0.75mm.
matthewwh":3g6otosg said:A third flat thing is needed - your kitchen worktop is probably flat to better than 0.75mm so it will at least be able to point you in the right direction.
I know it!phil.p":27n9nk2j said::-k He didn't say you'd find tempered glass in the skip.
A bit of mdf is also likely to be flat enough. Good for a laugh though, these crazy sharpening threads. :lol:Sheffield Tony":dzkdw0gl said:matthewwh":dzkdw0gl said:A third flat thing is needed - your kitchen worktop is probably flat to better than 0.75mm so it will at least be able to point you in the right direction.
So there you go - forget all the fancy glass plates, just stick some wet or dry onto the kitchen worktop. (If you dare !)
One other thought about the flatness of glass - don't try using an old sealed unit; they are normally concave because they are partially evacuated !
And dont leave a bit of sawdust or a shaving in between either (hammer)Jacob":2grint1x said:Yes the glass will move so it needs turning regularly to balance surface temperature and also supporting on something flat. Frinstance another piece of glass, which will need supporting.... etc etc.
So you have a big stack of plate glass, and turn and shuffle them between each stroke with a honing jig.
Don't drop them!
Cottonwood":34j85ia8 said:And dont leave a bit of sawdust or a shaving in between either (hammer)Jacob":34j85ia8 said:Yes the glass will move so it needs turning regularly to balance surface temperature and also supporting on something flat. Frinstance another piece of glass, which will need supporting.... etc etc.
Don't drop them!
Corneel":14frqn7e said:I've heard often that glass isn't really a solid but more like a very viscous fluid. It gives slowly away to pressure. Being no glass expert I don't know how serious this is but it could explain the pricesticker incident.
matt_southward":2twrbvai said:Thanks for all the replies, and different points of view.
I had almost decided to keep the glass as the underside was a bit flatter, but then that meant that it rocked about a bit on the bench :shock: so I will be sending it back after all.
I certainly don't see scary sharp as cheap! The reason I went with it for the moment is partly that I couldn't afford the initial outlay for some diamond stones (which I'd have preferred), and partly circumstantial in that I wanted something fairly quick to set up for the various things I've got to sharpen. I had a bit of trouble with my combination waterstone because of it's softness - I was sharpening whittling knives on it and kept catching the edges, and so it was getting a bit beat up and uneven. Plus I can only just fit my plane irons on it. As I'm using a honing guide at the moment so that I can get some consistent results for the time being - there's not a lot of room on the stone AND I keep having to true it. Also my 'workshop' is actually a spare bedroom so sloshing water about is also a bit of an issue. So scary sharp was really just an interim way of getting my tools ready for work whilst I'm learning all of this. When I can afford it I intend to get some decent quality, decent sized diamond stones, for plane irons, chisels and knives and any 3M paper I have left will be handy for odd shaped sharpening needs.
I wasn't really obsessing over flatness, I was just a bit surprised that the glass was out by so much after all I've read about the flatness of float glass (after a closer look I'd say it's about 0.3-0.5mm out in each corner, though I can't find my feeler gauges to check).
Anyway, it's all part of the learning curve I guess - thanks again for all the input.
matt_southward":e13n1r1x said:So I'm now pretty sure the float glass is crowned as I first thought, and so I'm concluding that you can't just rely on float glass being flat by way of it's production process after all (and my final best guess based on the thickness of Sainsburys receipt paper (all I had) is about 0.3mm - so down a bit from my first wild, half-blind guesses).
Well you missed a trick there. You have three straight (ish) edges to compare/contrast (glass, veritas, worktop). This is the way to ultimate straightness!! 2 not enough, 4 a crowd.matt_southward":fqvk7o9n said:Sorry, I've been busy the last few days...
From Ron Hock's 'The Perfect Edge': "if you are ever at a loss for something to talk about with a woodworker, just start talking about sharpening. It's a conversation that can go on an on."
I must admit that when I read that today it made me smile! Anyway, I tried Matthew's suggestion of testing on the kitchen worktop (though for the record Matthew I have a Veritas steel straight edge which I think is supposedly accurate to a thou), but then I realised the stupidity of what I was doing - at this point remember I'm basing what I'm doing on the assumption that I can't trust my straight edge OR glass and then I throw in the extra unknown of a kitchen worktop (is it flat or not - how would I know!!). Then I had a bit of a Matrix moment where I thought - 'there is no spoon' and gave up :?
How do you know? Personally I doubt it very much.and is howwould let you
Luckily enough, yesterday I received a Veritas glass plate from Axminster and this turned out to be actually flat
Doesn't matter, won't affect your sharpening, unless it's so far out you can see it with the naked eye. The eyeball is the ultimate arbiter in woodworking - if it looks straight than that is good enough...... So I'm now pretty sure the float glass is crowned as I first thought,
