As I have the glass already, I'll send the edges smooth and put it on a piece of MDF and see how it gets on. I couldn't get it to flex with a few bits of paper at the edges so I think it'll do the job for what I need.
They don't go bendy with age so if it was OK 20 years ago it still will be, and maybe just need a light clean. Usually rust on the blade, sole or sides isn't much of a problem and pits don't need flattening out - just a few quick passes over a sheet of wet n dry to remove the loose stuff. More likely to be a prob with the mechanism.Oh the plane's unusable, I think it sat in a box for years. My mum had it after my grandfather died and that's 20 years ago, it's pretty badly rusted but it's an old Stanley, I'm sure it'll come up just fine once it's been sanded clean and flat again.
I agree. most diamond stones would be far too small.I have one for flattening my Waterstones but I don't think that would be big enough for a long smoothing plane
Not if you put it on a nice thick piece or pieces of MDF well supported on the workbench eyc......
You stand some chance of causing an error (removing excess material from toe and heel) with such a long bendy length
Yebbut how would you check that surface?combined with not having a surface for checking at the same time.
For those that asked, these are the planes. The wooden one has three names stamped into the front end, one of them is my granfathers so it had a fair life prior to his ownership.
View attachment 146779View attachment 146780
Probably the most accurate straight edge I have is a Starret 30cm combination square, I can use that to get an idea of how flat it is when I'm working.
It'll be flat enough!......... worth noting that having a dead flat plate is no guarantee
that your going to end up with the same,
What is spot work?unless you do spot work,
Definitely not worth it.so the question is whether it is going to be worth rigging up a big lap everytime
I agree, if simply needing to eliminate some crud.It'll be flat enough!
Identifying high areas what one might wish to deal with, withoutWhat is spot work?
Agreed.Definitely not worth it.
If you just rub it up and down on a flat abrasive it'll show up the high spots in seconds. It's the first thing you do just to check it out before you do any work. If you carry on they'll disappear as the thing gets flatter.....
taking excess off toe and heel,
Or just keep at it on your flat abrasive surface. A lot easierfocusing on those areas with say a block
or a small strip on the lap.
eyeballs, and a ruler perhaps.Having something to check with is arguably more valuable than a flat working surface,
If you carried on assuming this with a bad case, you will likely end up with a banana profile and thinner ends of the plane than necessary, as abrasion will always favour the edges, i.e toe and heel, and you still would likely end up with a lump around the mouth.If you just rub it up and down on a flat abrasive it'll show up the high spots in seconds. It's the first thing you do just to check it out before you do any work. If you carry on they'll disappear as the thing gets flatter.
Or a plate which you could check things with, whether one does so with abrasives or other inspection techniques, be it feelers, hinging/pivoting, bluing with marker or whatever, much the same kinda thing which you'd need to check the glass in the first place.Or just keep at it on your flat abrasive surface. A lot easier
Very unlikely, barely possible even if you tried!If you carried on assuming this with a bad case, you will likely end up with a banana profile and thinner ends of the plane than necessary, as abrasion will always favour the edges, i.e toe and heel, and you still would likely end up with a lump around the mouth.
Avoid feeler gauges, hinging/pivoting (whatever that is), blue marker. This is woodwork not precision metalwork engineering. It's not rocket science.Or a plate which you could check things with, whether one does so with abrasives or other inspection techniques, be it feelers, hinging/pivoting, bluing with marker or whatever,
Eyeballs, and a straightedge if in doubt.much the same kinda thing which you'd need to check the glass in the first place.
