If you want to pay the commercial price for some novice made planes, be my guestCan I order a set?
Thanks. There are quite a few imperfections in this one, not least that the auger bit went through the back of the mortise. So it’s the “sacrificial“ test plane, if I knacker it its not a Big deal.They look good! Accurate ish is good enough - any precision depends on the blade itself.
Definitely! In fact the round is probably the easiest thing in the whole process.
You need accuracy on the sole of the plane, because you shape the iron to match the sole when sharpening.
Matching the iron to the sole is vital if you want the plane to perform properly.
Yes, both for the initial scribing and then on the edge to grind the point.Did you use layout fluid to mark out the iron ?
For what it’s worth I have 3d printed a no 14 sanding block, with 0.012 allowance made for the sandpaper.There's nothing quite like a steep learning curve.
I think you're doing well and I'm sure that once you get it sussed, you'll wonder what all the fuss was about.
YesQuestion - the blind side bevel doesn’t go right up to the mouth. I am guessing I need to plane this so it does? Else it will act as a depth stop?
I have some new old H&R's and it's about 1/2mm shy of the edge.Well, my 3d printed sanding blocks worked a treat and I have the sole flat to less than 0.004”, which is the thinnest feeler gauge I can find. I have honed the iron and I’m getting nice thin shavings now. But it’s still not quite right. It is skittering or chattering and still gets stuck from time to time.
I am thinking the next culprit is the bedding of the iron. I can unfortunately get the feeler gauge behind the iron. I guess I’d better go at that next.
any advice welcome.
Steve
But the blade will all be proud of the sole, will it not, if you squint down the length from the toe?
No
Well I’ve done it now.
Yes, they get moved about a bit like carving, so any lip or edge that forms gets removed by the next pass and they are always cutting a fresh profile.But the blade will all be proud of the sole, will it not, if you squint down the length from the toe?
PS Come to think - a hollow or round is different from rebate or moulding planes in that the the H&Rs are moved about and cut the sides of a hollow wider than the plane whereas the others are used on a fixed line to deepen the same profile.
That iron looks good - consistent and sharp. I am struggling to get mine like that. What technique did you use?
Yes I was guessing!
