How do you know? You said you don't build furniture. Burnish with which set of shavings? The ones from the power planer? scrub plane? jack plane? jointer? smoother?
How many different wood finishes have you ever applied?
I think you're confusing burnishing turned parts on the lathe while under power. Rubbing mouldings and other curved parts by hand with some set of shavings isn't going to do much if anything at all. It takes a while to notice any difference on a turned part spinning at 800 rpm or more. It might take more time to burnish a part, well, on a lathe than it did to turn the profile in the first place. In fact, it probably should as a rule.
Otherwise, I think that 'burnish it with shavings' is mostly so the 'I've never used a scraper or sandpaper' crowd won't spoil their own narrative, if not their own delusion.
